3inch body lift??????
If you see a 4x4/fx4 with a 3 inch body lift on it, it sits up pretty high you can tell its lifted. If yours is 2wd leveled and if you add a 3 inch body lift and also add taller tires, you will have pretty much the look and height of a stock leveled 4x4 without a body lift. Your not going to sit the same comparing the same lift truck to truck. because from the start the 4x4 sits up like almost 3 inches taller from the beginning, those 2wd year models sit fairly low and those 4x4s in those years sits up pretty tall, but dont forget if you dont add taller tires your definately hurting some possibly gained height.
