6" to 8"
I wasn't able to run my rc 6" with a 2" level, the upper control arm hit the spring, i spent hours trying to figure out why i couldn't run this setup when i seen others do it just fine (search for my old post) i figured out with the rough country kit the lower control arm brackets only drop down 5" (basically your losing an inch) but they use a giant 6" inch spacer to achieve the full 6" of lift, so to make a long story short the most you can run is a 1" level kit on top. bilstein does make adjustable front struts use can use but im fairly certain u will only be able to run them at the 1"setting. hope this helps.
