'09 2" AS leveling kit impact on suspension w/ pics
Answered mine, thanks. It looks like the AS 2" lift gives almost another 1" of lift over my Revtek 2" lift. I'm trying to determine if it's worth it to change it out at this point. I like the rake of my current setup but who doesn't want to be an inch higher!
-Jeff
-Jeff
i just ordered the AS 2'' leveling kit and the readylift 3'' blocks for the rear. by the looks of the KR on the first page it looks like i made the right decision. it will have a little rack if any, but should looks some what level. hopefully i can fit 35'' toyo mts mounted on 20'' bmf novakanes. im hoping this works since i havent seen this setup any were yet.
That was the main point. I suspect my upper ball joints will fail early. When I replace them, I will consider swapping my 2" AS kit with a 1.5" AS kit. It is only 3/16" shorter (1 3/16" instead of 1 3/8" if I recall correctly, but every bit will help). I cannot imagine what this looks like with a 2.5" or 3" kit. I would love to see pictures similar to the ones I posted if someone has this on a '09 or '10 4x4.
