FINALLY got my 37s on
For that purpose they will do exactly want you want. If anything I would do the body lift especially if you go ahead and purchase the Bilsteins.
If you add any more suspension lift to the front then you will start having issues with your ball joints and cv's. 2.5" is the most I would push. Even if you were to get the coil overs and crank them it wouldn't be serving the purpose you want it for. In order to not cause horrible angles you would only be able to crank them to achieve an additional 2.5" of lift which would put you back where you are now.
What offset wheel do you have? I had a -25mm offset 11" wide wheel and didn't have any rubbing with the 37x13 Kumho's. I know the Toyo's are a little wider, but not by much. The new owner put the Bilstein's on it and now has minor rubbing, but think it's only when he turns and hits a bump at the same time.
