FINALLY got my 37s on
Old 12-31-2010 | 05:21 PM
mote88's Avatar
i will post pics later tonight finally got my 37/13.5/17 toyo mts on 6in suspension 2" aal, 2.5 AS.....now i love the look and everything about it but i have a rub at full lock....now the question is if i did bilstiens and cranked them would it give me lil bit more lift in the front than the leveling kit and 6in procomp spacer? if not i can live with the rub but if bilstiens will lift it a lil higher i will go with them...thx for the input will post pics later
Old 12-31-2010 | 06:27 PM
dozerdog's Avatar
hurry up with the pics! you're killing us!
Old 12-31-2010 | 11:05 PM
wandell's Avatar
Do you mean combine the 6 inch lift, 2.5 inch leveling kit and Bilstiens? No, you can't do that. Also the Bilstiens only go up to 2 inches. So if you remove the AS 2.5 inch leveling kit and install Bilstiens you will lose 0.5 inches of height.
Old 12-31-2010 | 11:18 PM
08FX4's Avatar
x2.
Old 01-01-2011 | 02:10 AM
USAFORD's Avatar
you can always loose the procomp spacer and get coilovers and crank them.
Old 01-01-2011 | 09:01 AM
mote88's Avatar
So if I get coilovers with AS will I have more lift than now?
Old 01-01-2011 | 09:10 AM
USAFORD's Avatar
Alot of guys are running the 6" SL with coilovers cranked and not rubbing at all.. But yes, you could get the new coilovers(from fabtech, procomp, etc) and add a Leveling kit ontop of that, but you would be sitting higher in the front then in the rear, you would need an AAL to level it out
Old 01-01-2011 | 09:37 AM
mote88's Avatar
I already have an 2"aal in rear I like the bullydog stance anyway....how much are the procomp or fabtech coilovers?
Old 01-01-2011 | 09:50 AM
DarkShadowSTX's Avatar
Mote, you are horrible when it comes to posting up pics. We're still waiting for your light bar pics in another thread too.
Didn't you ever here the most important rule on this site? Pics or it didn't happen.
Old 01-01-2011 | 10:33 AM
USAFORD's Avatar
different places have them for different prices.. plan on spending atleast 1K on the coilovers, if not more
Old 01-01-2011 | 12:49 PM
mote88's Avatar
here they are took with phone s****pics but better than nothing
Old 01-01-2011 | 12:50 PM
mote88's Avatar
think im gonna order the 4-6 bilstein 5100s and put 2.5 AS on top of tht
Old 01-01-2011 | 01:09 PM
08FX4's Avatar
You can do that but you'll be doing yourself no good if you're wanting to achieve more height since the Bilsteins on the 6" setting with your leveling kit on top will be the same height as what you already have. As for adding more lift you are already at the max right now unless you install a body lift or a bigger suspension lift. Right now you are 2 1/2" above what the suspension lift is designed for which is basically the same as having a 2 1/2" leveling kit on a stock height truck.
Old 01-01-2011 | 10:12 PM
wandell's Avatar
I agree.
Also, your truck looks great!
Old 01-01-2011 | 11:28 PM
mote88's Avatar
yea i understand tht the bilstien wouldnt help but just looks better and rides better....guess after i get gears put in a couple weeks i will get a body lift or coilovers idk which one though
Quick Reply: FINALLY got my 37s on
