Guys i need your help on this one please help
I got a o5 ford supacrew with a 2.5 level one the front and 1.5 blocks on the back i want to lift 6inches and change the broke to some more heavy durty brokes and i want to know what size tires offset etc. What kind of brokes i want to do some 22inch rims any info will help thanks alot
If you"re going to run a 6" lift plus the 2.5" spacer you may want to get 37's. Everyone is entitled to there own opinion on what offset. I like a negative offset with the wheels sticking out some. It gives a wider and beefier stance. For the rear you will need to remove that 1.5" block. I went with a Procomp lift which used the factory block plus a 3" block. I ran that for a little while then replaced with a 5.5" block and shim to angle the rear end. When I added the 2.5" spacer I installed a 2" AAL in the rear. As said above you will have to watch what lift you get. I know the Rough Country lift will not allow you to stack spacers. If you can I'd save the money and get the Bilsteins. It'll give better cv angles and ride smoother.
Here's what the set-up your asking about will look like depending on what weel/tire set-up you go.
