New front strut assemblies
I don't know if a spacer could cause them to fail, but remember, my truck has 171k on it. Could the milage play a factor in how badly the spring sags? Something just came to my mind...If the shock inside is good and the spring is worn out, that would explain the shock being so compressed because the shock has an extra load on it and it cant hold the whole weight of the truck. that sounds just about right in my opinion.
Think about it like this...remove the coil spring and re-install just the shock...what would happen?? The truck would instantly collapse the shock completely and fall to the ground. You can compress a shock absorber by hand...how then would it have the ability to hold up a portion of a 6,000 lb truck??
Also...remove the shock and re-install just the coil spring...what would happen?? Nothing. The truck would sit exactly as it does now.
171K is sorta getting up there in mileage, but not off the charts. Definately lots of trucks running around with that much mileage and/or more without requiring a spring replacemenet. As a general rule, springs and such are not normal wear and tear items.
Those spacers also don't compress the spring further. The spring still sits between the stock perches with just a spacer, so it doesn't really do anything unusual to the spring itself, unlike ball joints and stuff...it just spaces everything down to lift the front.
Is that $167 for the entire assembly with coil spring and everything?? Don't know what you want to spend but they're are some very nice options out there, even stock replacement...Icon, S-A-W, Fox and maybe some others have some really awesome coil-over set ups. They're pricey...but they're bad ***!!
Here's S-A-W...they have really good stuff...but be careful, they refer to them as coil-overs for your truck, so you may have to take that into consideration when compairing their products to "the shock warehouse"...LOL
http://www.swayaway.com/VehicleMake_2.php
