37s with a leveling kit?!
Saw this truck and it appeared to only have a leveling kit. I looked at the front cross member and it was the stock one along with the spindles. So is it just a 3" LK or what? The tires are pro comp xtream M/T 37/12.5/R18
Tire size
Front trimming
Rear of front fender trimming
Close up, Front drivers side tire
Full side view
Tire size
Front trimming
Full side view
For the most part yes, depending on the exact tire, you may have some rubbing at full lock. With my tires, other than a little power loss I have not experienced anything different from stock.
You lose next to all droop travel with a leveling kit leading to the truck riding harsher because it has less capability to absorb bumps and dips. Larger tires will limit upward suspension travel if they can't fit in the wheel wells when stuffed upward. More-so the issue comes with the major loss of droop travel, this is why I advocate full suspension lifts over leveling kits anyday.
Good topic
