Belltech 3/5 Drop on 08 screw, front looks a little higher than rear
thats why i was asking. just making sure you put them in correct. do you have the 6.5' bed? hlb had to put helper bags on his because his sagged in the rear due to the extra weight from his 6.5' bed.
I have the standard size bed, 5.5 I believe, what ever the smallest bed is that's what I got.I did use the belltech supplied shackles that came with the flip kit. Thanks for your help I will just put helper bags on it. I will post some pics once I get my 24's installed as well.
If your having problems still with the front being higher than rear call the tech department over at Belltech or email them info@kwautomotive.com
I did that the day after the install their only response was that if the truck has ever been used for towing or has had a heavy load than thats why it would be sagging. I have never towed with the truck and everything was installed correctly, the only thing that I think may had had a negative effect on the rear leaf springs is the fact that I was running a level kit on the front prior to lowering it but I really don't know why that would have been an issue. I am just going to get bags and call it a day.
no I measured the rocker panel at the front of the cab and then at the rear of the cab and it sits 1/4 of an inch lower at the rear. I does seem like its starting to settle though. I did have a level kit on it before though and the rear did sit a bit lower.
