1.5" or 2" AS kit??
1.5" or 2" AS kit??
Well I'm looking into doing a leveling kit on my pickup, but I can't figure out what I want to go with.
After it has been leveled, I know I need an alignment afterward.
But how much lift do you actually get after the alignment?
AND Which kit would you guys recommend? the 1.5 or 2"
I would still like to have the rear a little higher than the front..
Here are the kits I'm looking at:
1.5"
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
2"
1.5"
2"
1.5"
2"
1.5"
2"
His sets with a very very slight rake, but looks Good in all the conditions I explained above with my truck. If you dont intend to haul at all and no towing, go with the 2", it sits level under perfect conditions.
I do intend to pull different thing. Boat in the summer, Delivery trailer year round on different occasions.
But I'm sorry I don't really have a good picture of my pickup. I am in Phoenix, AZ with my fiance to get some stuff done at the Mayo Clinic.
We should be back in town by the weekend though..
You need to measure your truck first off and see how much rake you have, then go from there. Not all of these trucks are going to be alike.
I put the 2" on mine and it lifted the truck 2 1/2" (swb, reg cab). It has a 3/4" rake now and I had planned on a little bit more for towing.
How did it lift the truck 2.5" with just a 2" kit?
You generally get more out of an AS kit than what it is listed as, from what reading I have done one here after the fact.
I ordered the 2" kit from AS and that's what it said on the box but after install, it was 2 1/2" higher than it was before install.
The spacers themselves won't measure the same as what the kit is rated for. They will be shorter. The geometry change to the front suspension is what gives you the additional height over the thickness of the spacer.
edit - after taking a good look at your sig, I like how yours sets better than mine. I often wonder if I didnt get a 2.5" kit by mistake. I have 0 rake, and slight sag under load and pointing up hill.
