2.5/3" leveling kit
2.5/3" leveling kit
so i'm kinda new on here and i was wondering if i can get some good advice or suggestion regarding the 2.5"/3" leveling kit i tried to install on my 98f 150 2wd which are the two coil spacers but the problem is that it seems to put too much stress on the upper control arms added to the fact that are short and hitting the frame every time i hit a small bump or hole. so my question(s) are should i replace the upper control arms with longer ones and where could i find them?
do i need longer shocks? or am i better off by just cutting the springs an inch or so in order to keep everything stock and maybe get a smoother ride?.
any comment advice or suggestion would be very helpful thanks for your time.
The biggest spacer you want to put on top of those springs is 1.5 in. To get 3 ins you need lift spindles
Also they make a kit with the lift spindles, 3in lift springs and longer UCAs, 4in block in the rear, and longer shocks and you get a 6.5in lift
Before with the 1.5 in spacer
After with the Lift Springs, Spindles, and Rear Blocks
thanks for both of your advice i just took the 3 in spacers off and i guess i will go with the spindlescause honestly i liked the way it looked with the 3 in spacers even though it wasn't working. so i ordered the spindles the are on their way now would i need anything else besides the 3in spindles? i will keep posting the progress on it and eventually i would like to put either a body lift or could i just use the spindles and the 1.5 spacers on it? thanks again for your reply
The 04-11's are a completely different suspension system. Pretty much everyone has figured out that 3 inches is just too tall for a leveling kit. As far as I know your only option is to remove the 3 inch leveling kit and install a smaller one.
This is my setup as is with the 3" level in the front and the 1" block in the rear, sittin on 315/70/17's w stock BS, think this will look awkward with a 4" lift?? I kinda like the Rough Country lift bc of the price, any thoughts where to get the cheapest but quality 4in lift from??
