AAL with 1.5" leveling kit
I recently installed a 1.5" AS leveling kit and the back seems to sit a little lower than the front. Has anyone installed an AS AAL with a 1.5" leveling kit? I've seen a lot of guys adding the AAL with a 2" or 2.5" level but none with the 1.5". Will the back sit higher than the front again?
TIA.
TIA.
you might think about airbags as you can then adjust them to your desired height. If you get an AAL, you may get back too much "rake" and get frustrated.....bags are going to cost more, but if you ever tow or haul heavy loads it will allow you to put your rear end where you want it as well as stabilize your ride.
