about to buy lift components. HELP!
you arent going to get a good looking beefy truck with the MPGs of a prius so you just gotta get over tht part honestly. I deliver pizza and I just jacked up my truck, it took me awhile to just stop worrying about my mpg bc its not gunna change no matter how much I worry so I just enjoy my truck for what it is.
What you want to do is going to look dang close to my truck. I went spindles,coil spacers,3"block and 5100s. I got the springtech 5.5 kit but used daystar coil spacers as the spingtech aluminum ones are junk. Then got new shocks from 4wheelparts. The coil spacers/spring sagged so my truck is back down to about 0.75" tail high from the level it was when i first installed the kit.
Go with spindles,2" lift coils, and 3" blocks. I run 305's too and with a little valence trimming they fit great and make the truck look beefy. My poor little 4.2l doesn't like heavy steel wheels and 33x12.5s so I might go to 4.10 but with a v8 3.73s will probably be low enough without going so low you loose mpg on the highway.
Its a little taller than a stock 4x4 but you can tell its lifted. I live in a city so I need to be able to get into drive throughs and parking garages so its the perfect height. Its big enough to tell and get around off road without looking like a so-cal flat biller with a huge lifted 2wd.
Do I want my truck higher? No. I want it leveled out again but not higher.I was going to put on fiberglass fenders to fit 35s at my current lift but they got stolen.
