Has anyone done this?
I've been trying to get my truck level for a while now and had no luck. I put a 3" leveling kit on a while back and my front end still sits an inch lower than the rear.
So I was thinking about taking the 2" rear block out and replacing it with a 1" block to level it out. Has this been done or is it recommended?
I haven't tryed replacing the front coil-overs yet because I don't want to drop $350 on a new pair and realize they didn't level it out either.
I know my current coil-overs are the 4wd version, but I'm starting to think the spring itself is worn out. Any help will be appreciated
I know on the 04 / 05 models it did take a little more to level it out but if you are still 1" low after a 3" kit you have something else going on. I suspect some serious suspension settling, so yea you should look into replacing your coilovers, once you do that drop back to a 2 - 2.5" kit.
