Nose-high
Nose-high
Alright guys, I've come to the realization that after installing new shocks, 1.5 inch spacers and 3.5 inch spindles in the front, the 3 inch rear block wasn't quite enough to level it.
I'm wondering if 1. if i turn the blocks 180 degrees will it make it different? i noticed they had a weird slope to them, and i wasn't sure as to which way to turn them. and 2. if that doesn't affect it, what are my options? Just add-a-leaf or replacing the block (wasted 75 bucks) ?
well i just checked and my rear blocks ARE facing the right angle. I just remembered that i wasn't sure when installing so i turned the block around to see and it physically doesn't let you put them in backwards, due to the pinion angle (good call SAWMAN556). As for the it all settling, how long should that take? I did the work to it 2 or 3 weeks ago. And if my springs are worn should i get an AAL or replace the springs or what?
