2wd lifting
rcd makes a 6" lift for you 97'. spindles, coils, sub frame, sway bar links, anti-compression struts, and bilsteins all the way around. check rcd's website. www.racecardynamics.com
even though mine is a 98, I thought I'd show it anyway. Sizes and such are on my homepage.
www.f150world.com/imdamoninfla
it all depends on your application. are you going for altitude or performace. general offroad or high speed desert. if you are going for just altitude there are numerous kits out there. but if you want wheel travel and performance i would recommend the
kit from camburg engineering. they seem to have the most durable kit for the truck. however they can be pricey, but i think it is well worth it.
www.camburg.com
www.camburg.com
