8in questions
8in questions
new to the site.. im wanting an 8in lift and 37s but not sure which kit to get.. rize or bds?
also my 99 f150 the stock front drive shaft work with the 10in lift no problem. but rize and bds both say it may need to be longer? so will i need a new front drive shaft or will the stock work?
oh sorry the 99 was my old truck i had put a 10in whiplash suspension and 40s on it. the stock drive shafts work fine on it, so i didnt understand why my 07 f150 screw would need a spacer/new one. has everyone with the rize kit needed a spacer/ new?
I went with a 12inch Rize and also had a 2inch leveling kit and drove several hundred miles with the stock driveshaft. Then i put a 2inch spacer on th edrive shaft to be able to drive it to houston from ft hood. Did perfectly fine for me but i just got a new one for 400 custom made. Only thing i can say is put that bad boy under there and see how far out it comes and the angles. Who knows you may luck out like your last truck
