Bilstein 5100 Leveling Shocks Question
Before I order all four shocks for my '05 FX4, I just wanted to know if anyone here has these installed on their trucks?
My question is, do the shocks come with all of the required hardware for the level, or do I have to purchase the blocks, spacers, etc?
Also, does anyone know what max size tire I can put on my factory 18" wheels? I've been hearing some conflicting thoughts.
Thanks all for the help!
You will need nothing besides the shocks parts wise. You will need a coil spring compressor or take the assembly to someone with a press after you remove it. You can get 34s on there some will tell you 35s but in my opinion just because you can fit em doesnt mean you should.
Appreciate the help!
Jughed, how do you like your 5100s? I was thinking about running 33"s on mine when I install the shocks. The only reason I was asking about the shocks was from some of the research I've done, it looked like the pics certain Web sites used for the description showed different images. I just wanted to make sure before I spent the cash for them.
