Alluminum Blocks
Alluminum Blocks
Anyone using them? I have a 3" set and was thinking about using them. They are solid in construction and I am told that they are aircraft grade alluminum. I am a little concerned but considering using them. Everyone says they break but has anyone on here actually broken one??? I have seen broken cast blocks but only because they ubolts came loose....They are Procomp who of course assured me they would not break or slip out...
I agree. I just read a few posts about aluminum blocks corroding between steel springs and steel axle due to indifferent metals. They are 6061 aircraft grade....I can't imagine they would corrode either but who knows...
I got them for free and installed a add-a-leaf so that I could use a smaller block due to axle wrap....Think that I am going to try them...
I just assumed that this add-a-leaf would settle a little bit but it has not at all so I am considering a smaller block. Better for axle wrap anyways though....
Its gonna take alooooong time for you to notice that aal sagging. Plus its always better to go with a smaller block than a big one to achieve the height you want. maybe you can sell the 3 inchers or something? But if you decide to use them they are definitely a great quality and should feel confident in using them.
any corrosion???? I am sure that it would take pretty much the life of the truck for it to corrode but it seems to be a topic on this site as well as others, Electrolisis and such...
I might have jumped my 97 over a field entrance while looking for my phone after a golf tournament. I actually broke the nub off of the block and bent the bolts. I also cracked a wheel. It was not gentle. I had to replace the bolts and block. If you get to the point of breaking one, something is going to break anyway. Just my opinion
