Straight axle conversion
I'd like to do it to my f150, but it would suck on the trails around here due to the width.
I would like to keep the 6 on 135 patteren to use my rear end, rims and tires, cutting expense. I know that 1/2 tons are weeker than 1 tons. This truck is a pavement princess. It just needs to hold up driving up and down the road... I guess I am wondering more specifically, Has anyone ever had a front end made with the 6 on 135 pattern. As fas as suspension, I will be building it myself. Whether its bags or coils the front would be four linked w/ crossover steering.
Anything can be done but money is where it's gonna count if you wanna convert the front axle bolt pattern.
You could always just get a front axle with a different pattern and get the same kind of wheels you have to match the back ones, unless your rolling on factory rims still. Only downside is itd make rotating tires about impossible without spending a chunk of change to change the wheels on the tires around.
The last build I did was a 98 Chevy S-10. We did a 6 lug 44 up front and did a cut down custom dana 60 with the matching 6 lug in the rear. Willwood disk brakes etc... I know that the rear can be done with aftermarket axle shafts, just not sure about the front. Say taking a 60 and changing the bolt pattern???
