New front struts for leveled front end
So I have been thinking of leveling the front end of my 2005 SCrew. But have had a lot of friends tell me it makes for a rougher ride due to the struts having less travel. So I was hoping for a recommendation on a nicer strut to replace them with that have more travel.
Replacement struts are a stiffer ride, some prefer it that way. You can go with bilsteins or ranchos but some people say the ranchos don't give the full lift they say.
A spacer such as the autospring kit won't affect your travel because it mounts over the strut so people say it stays closer to the factory ride, just DON'T go over 2.5".
Leveling it won't change how harsh it rides. It will make your steering feel like sh*t though. By leveling it, some weight is shifting off the front tires and that makes the steering feel very numb and awkward. It gets worse if you try to haul or tow anything.
But if you insist on doing it, make sure you get it aligned immediately afterwards and tell the tech to set the camber as far negative as possible (while keeping it in spec).
Belltech makes a nice Strut. It lifts and lowers as well.
2WD
http://thesuspensionsource.mybigcomm...g-strut-25001/
4WD
http://thesuspensionsource.mybigcomm...g-strut-25002/
2WD
4WD
Just put factory 4wd struts on it you get about 1.5 inches higher than 2wd and its only an inch off from when you would do a 2wd strut plus the leveling kit. I did this to my truck and yes it does ride smoother without the leveling kit. No problems and perfect fitment if you do want to go with the more clearance with the leveling kit I have one if you would like to buy just pm me. Hope this helps
