BDS 6" with Rancho RS9000XL's?
Hey Everyone,
I am on the verge of FINALLY putting in my lift kit and ditching the, bad idea, 3" level kit. I was going to go with the Rancho 4" lift as it gives over 5" on 06 150's, however they have been discontinued & no one has them.
I need to keep my stock rims until I can aford new ones, so I've decided on the 6" BDS. My concern with BDS is that it uses a spacer and stock coilover. Can you replace the spacer with the Rancho 9000 shocks? How would you determine the right size?
PS thanks to everyone on here, I'm pretty sure I have read every lift kit post here!
Hey Everyone,
Now, as to your question...The BDS kit comes in 2 configurations. You can get the 6" strut spacer or you can get the replacement 6" strut like I did. The price is about 500 dollars different but I also got the Fox rear shocks and the driveshaft spacer. I love how mine turned out. The only thing I am worried about is that the 5" rear blocks that come with the kit arent adjusted to correct for the pinion angle. My driveshaft is pulled out about 3/4" and that is with the driveshaft spacer installed. I have the 5.5ft Supercrew so that doesnt help either.
Anyways, If I were you i would talk to your local BDS dealer and go with the replacement 6" struts from BDS. They ride great and since I had 94,000 on my stock struts I figured it was time to replace them anyways.
Oh and I wish I could get pics to upload on here but I have pics on the other forum if you want to see what mine looks like.
