Front end rattle. Need help
New to the forum. Thanks in advance for any help. I've got a 2000 4wd supercab 5.4. I have an incessant rattle in the front end. It rattles over bumps, especially washboarded dirt roads. I have localized the noise to the passenger side front end. I replaced the tie rods, hubs and upper ball joint. The shocks were replaced less than a year ago. The lower arm was replaced 18 months ago. I am having trouble keeping the sway bar centered. The links were also replaced, as well as the bushings. Any ideas what may be causing this rattle? Again, thanks for any help
Did all the work myself, except the lower control arm, which is bushed. All done in the last 6 months (except control arm 18 mos. ago). The control arm was replaced earlier because it was bent. I do a lot of hunting and the suspension takes a beating. I noticed the rattle last season and tried to eliminate by replacing components that would need replaced anyways. I am completely flustered!
Just my theory but maybe someone else has a idea lol
