I wanted to get a leveling kit on my 06 lariat 4x4, I want to be able to fit 35ʻs with none or minimal rubbing.. Does anybody have suggestions or opinions? post a pic of yours if you got one! thank you
Use stock wheels, check the true measurements of the tire on the manufacturers website and try to go no bigger than a 35x12.50. Also the less aggressive the tire is, the less likely it'll rub vs one that's very aggressive of the same size.
