RCV ifs axles
They make axles for anything.. custom 930cv joints with custom heat treated chromoly axles. You give them an extended length and a compressed length and bingo. so yes they do make axles for you if that's how you roll..
ya definitely not just a upgrade I would get if you were doing normal things. I am ordering a pair in a few months. the 930 High angle cv is really nice. less friction more angle less bind. I'm running heat treated shafts now and I have only broken one due to a bad shaft to begin with. run the stock stuff, they will hold up to a lot more than you think they will trust me. if they shred a boot, or bind then your suspension is off and needs to be addressed accordingly. otherwise you should be fine!
