6" lift and level kit
Yeah, essentially some kits drop all of the suspension parts, which provides the lift, and if the crossmember/subframe is only 5" versus 6", it's effectively a 5" lift with a 1" level already right off the bat. RCX seems to be the main culprit with doing this, and to what end I'll never know, but the majority of lifts for the 04+ trucks are a true 6" if I remember correctly.
We might be able to tell you what brand it is by looking at the crossmember
If that's a Procomp, then you're good with a 6" drop. If it's not, I dunno how much the drop is. But your angles will really determine how much you can add. I'm inclined to say no if your angles are causing contact right now, but it all depends. The Bilstein struts are the cheapest method of adding lift properly. Going with uni-ball or new uppers can help depending where stuff is hitting and how they're shaped. They're pretty pricey too. But I'd definitely go with some coilovers if you're willing to drop some coin. They can be cranked to 8" and are the best money to spend vs. new upper control arms.
Pizzaman is much more knowledgeable with all of this though.
And uni-***** are stronger than ball joints but that may not be needed in your application.
Either way before you go to those, you need to solve your stacked spacer issue. It's unsafe.
