3" preformance acc. body lift questions
I was considering purchaseing a preformance acc. body lift for my truck but have a few questions. Do you have to extend the gas filler hose, and any wires when you install this kit? also I plan on buying a fith wheel camper in a few years and want to know if this will affect how the hitch mounts in the box.
1997 F-150 4*4 xlt ext. cab
k&n filter
body gaurd bug deflector
duraliner box liner
1986 SUZUKI LT250R QUADRACER
5 speed,
uni air filter
chopped exhaust
tm32 traded fo tm 34
k&n filter
duraliner box liner
5 speed,
uni air filter
chopped exhaust
From what I know, the PA kit comes with everything that you need. As far as wires go, relocating a couple will most likely be the case, nothing major. The new bumper brackets are not strong enough to tow with, I wasnt sure if you had a hidden hitch or not. I would reccomend the lip gurads if you do plan on doing this. Otherwise, you might find it helpful to cruise through the other posts, a lot of body lift ones lately. Also, on this site, under PRODUCT REVIEWS, is a detailed install that I found helpful.
Good Luck
Good Luck
