2008 dana super 60 in a 91 F150 Mystery ball joint
Howdy all,
I need help IDing a ball joint mounted to the axle housing tubes:
The dealership parts dude was at a loss and I need this joint before I can proceed with the swap:
If you know what to call it that would be great, if you know of a part number that's even better. I kept referring to it as a stabilizer joint as it just mounts a piece of bar stock steering rod like rod...but no one knew what I was talking about.
Thanks for the help!
Thanks for the replies fellas!
I Googled side to side brace coil suspension and fabtech's suspension 101 called it a track bar...so I guess you're both right!
http://www.fabtechmotorsports.com/suspension-101.php
