lower arm frame mount bracket issue
greetings , I just bought a used 2002 F150 that has a fab tech coil spring suspension set up and fox shocks,sounds cool right ....kinda , cause what seems to be happening is the mount bracket located on the frame has enough play to allow the entire arm assembly to rock in the bracket about a 1/4 of an inch back and forth . the noise it makes is horrible popping clunk noise that can be felt through the floor. I cant find any information on how to repair ......Any thoughts?
