front end shake
front end shake
ok guys where do i go next?? i have a 2002 fx4 5.4liter. the problem, im getting is at higher speeds (60+mph) i start to get really bad wobble in my front passenger tire, it seems from looking at the back side of the tire it is wobblin bad enough to hit the upper ball joint in random spots. my power steering gear box was going out so i changed it. ive rotatedthe tires to rule out a bent rim or bad tire. still there so today i moved on and changed the tie rod ends both inner and outer and also the idler arm. the problem still exists
