33" E rated tires (shock recommendations please!)
Hello all. I've done some searching but haven't quite found what i'm looking for so looking for a little help. I've got a 2003 FX4 screw with 150K miles. The shocks appear to be the original factory "ranchos". I leveled the truck a couple of months ago and now have a much harsher ride (which i expected). I also have installed E rated BFG's (285-65-18) which has made my driving experience even worse. I want a smoother ride and given what i have provided would like some recommendations. I drive 90% city/hwy and do very little off-roading (deer lease, beach, etc.). Thanks in advance!
Those 9000's are a little pricey and i seldom will ever have a need for any adjustments as i'm pretty much on the pavement and don't play or abuse this truck. Just looking for a good all-around shock at a reasonable price that will smooth out my ride. I guess my confusion (or question) is the degree of dampening i should be looking for. Although not maxxed out, i did crank my t-bars quite abit to level this truck and by doing so really made for a stiff front end. Should I be looking for a shock with less or increased dampening ability? Thanks!
What's your tire pressure at? Often times airing down a bit will improve the "harshness".
The reason I got the load range E tires is because I tow, and when I am towing, the hitch load, plus the load of things I pack in the truck bed, along with the bed cap increases the loading on the axles to very near the limits of the OEM tires (measured on a CAT scale). So, when I load it that heavy, I increase the pressure all around to 55 psi. Both settings seem to keep the sidewall deflection about the same for the two loading conditions.
AND, I've found that my ride is very comfortable, actually better than with the old Goodyear Silent Armor tires that I replaced.
I think your harsh ride is due to the suspension change, and agree with the advice to reduce the pressure in the tires. If the ride is still "stiff" (no springiness) you could try a shock that has less dampening ability, but I think I'd go with adjustable shocks too, because if they aren't and the new ride is not right, you'd have to replace them too.
- Jack
Your best bet (IMO to try and keep cost down) is to stick to a twin tube design shock. A monotube will be a firm/responsive ride. Some people like this style of ride and we do really well with our monotube but some find them to "harsh.". We make a shock for a "level" that covers 1-2.5" up front. E tires are just a tough tire.
Guys, thanks for the input! So tell me Rancho, are you recommending the 9000s still, or, by "twin tube" are you suggesting the 5000 in lieu of a monotube such as the bilstein 4600? J&J, I agree with you on the adjustable shocks; I only want to do this once. I too have a trailer i plan to pull from time to time which is the reason I bought these tires (not to mention the shop gave me a pretty good deal so they could get rid of them).
You mentioned cost so that is why I suggested the 5's. I REALLY like the 9000's they are legit, especially if you do decide to trailer. The 4600 is still a monotube so maybe too firm. Another thing about the 9000's, if you don't like them you have 90 days to return for a refund.
Both us and Billies come with a lifetime warranty, so that is a plus for you.
You have a super crew (2003) right?
thanks Rancho. I've raised the front close to 2" and do not plan to go any higher, or, install a suspension lift (however, i might go with a bodylift, 34" tires and gears sometime down the road). Can you provide me the part # for the 5000 and 9000s? I seem to be getting different numbers from a few suppliers and want to make sure i have the right #. thanks alot!
Hey Dewalt. I had the silver bilsteins on my '03 Cummins QC4X and loved them. I even ran duals up front, mainly for the looks and believe it or not, the ride wasn't too firm at all. Still wish i had that truck!
