Best HD rear shock for towing 2014screw
The trailer itself is 2500 lbs, when loaded down its normally between 6,000 and 8500. Rairly do I get above that.
For the shocks I am just looking for something that will take the daily abuse of a loaded or unloaded trailer bouncing the back end of the truck around.
I burn through the stock rear shocks every 10-15K at max, when I pulled the last set off after 10K they were totally dead.
I need something that will last longer and perform better with and without loads on the truck.
Are the 2013 and 2014 rear shocks the same? Right now I am having a hard time finding much of anything for the 14. I know the fronts are different.
Thanks everyone!
