Rough Ride
Rough Ride
Hello
I have a 2001 f150 with the 4.6. My truck rides kinda rough. I put new tires on last winter. I haven't rplaced the shocks it has 194,000 miles on it. Like when you go down a country road it just rides rough. Would shocks help at all? On the highway it rides pretty good. Or should I just chalk it up as a 15 year old truck with a lot of miles and startin to just wear out?? Any suggestions would be appreciated!!!!
Thanks So Much!!!
Kevin
Thanks So Much!!!
Kevin
Hello
Thanks So Much!!!
Kevin
Thanks So Much!!!
Kevin
Did you put p metric or LT tires on the truck?
If any ball joints or tie rods do in fact seem good and tight, try shocks first. But check everything really well. The bushings may be totally gone at this point. Sway bar end link bushings also tend to fall apart fairing fast.
Moog problem solver would be your best choice with new front end parts. Just make sure to grease them every oil change. If you don't want to spend a ton, but was a decent shock, the high end monroes are good. Just don't get the cheap economatic. They're blue and easy to spot.
