Wheel stud questions.
I was considering upgrading my 12mm studs to a larger size. Do you guys think it is worth the trouble to upgrade these. I sheared one off then another off when I was backing off the nuts to fix the first one and their an easy fix up front, but what are they like on the rear drums, any help would be greatly appreciated. Should I go through the trouble of upgrading these with my tire size.
-Kelly
-Kelly
It was around $2,000 for the front kit. Add driveshaft, 10" springs and shocks and your getting up near if not over $3,000. As for the ride suspension really doesn't have much to do with that, when you get that big it's mostly all tires, and as for ride quality it's always gonna suck with Super Swamper type tires. You just have to like the way that big trucks drive. If you plan on installing this yourself be prepared because it's a big job.
-Kelly
-Kelly
If you know the right people. You can get the 12mm studs changed to 14mm studs for under $48. I bought the studs for about $1 a piece and did all the labor myself. The hubs had to be redrilled but that was it. I then bought new lugs for $1 a piece. The other $8 came from the 12-pack of beer.
Snowball
Snowball
I have since upgraded my studs to 14mm pieces from Ford. I got ripped off spending over $60 on studs alone! I got the lugs for $1 a piece from American Racing which is just south of my town. I had to drill 39/64" holes in my front hubs and rear axles to accept the 14mm stud nerl well, they sunk right in perfectly after that. I havn't had a slight hint of a stud problem since, it was a good decision to upgrade.
