2WD Spindle Lift Kits
call pro comp and ask what the back spacing must be for the stock rims to fit. i know with fabtech you can use the stocks if they are 4 5/8 i belive. if you looks at wrong17 he has the stock rims, so i say if you dont need to buy new ones dont unless you want to and the budget will allow you to. you dont need new a-arms you dont need new shocks in the front. you will need new shocks in the rear. if you buy a kit they usally come with front and rear shocks, so you might as weel change them while your under there. good luck
crain
The 3 inch gives the car more body roll but i think the new tires changed the handling the most. If you drive it normal then the ride feels the same. See, i drive my truck like a sedan, i take turns fast and with BFG TA K/O and 32 inch tires, it feels like i drifting when i do make a fast turn. Also the steering seems to be more sensitive and my turning radias is smaller. It also takes me longer to stop my car. But over all it is all worth it for the extra 3 inches.
