Bad wheel hop
Hi True Blue ....
That sounds like a broken shock to me. Or, it could be several other things. Like a lost wheel weight, worn out shocks, tires that are terribly out of balance, a rear end out of alignment or tires that have are worn so bad they have flat spots on them.
Something isn't right. And I don't think traction bars are the answer to the problem. First, I would make sure you haven't thrown a wheel weight. That's pretty common. If a wheel is terribly out of balance, it will hop bad enough to feel. And, if your shocks are worn they will allow it to hop even worse. So that is where I would begin my search for the root of the problem.
Traction bars are used to prevent "Spring Wrap-Up" under extreme torque situations ... like starting out or stopping abruptly.
They are great for that but you say you just have wheel hop while just coasting down the road? I'll bet $2 on a lost wheel weight. Let me know what it was. OK?
Hope I have helped.
BillVoyles
RedLowRyder
Hope I have helped.
BillVoyles
RedLowRyder
I had lots of Wheel hop too, but only when accelerating from a standstill... Traction bars elliminated the wheel hop completely. However, I now have tremendous wheel spin. I'm in the process of replacing my 30 gallon fuel tank with a 16 gallon tank placed behind the rear axle. Should help in getting the center of gravity of the rear axle. Not much, but it'll help.
