Cam Bolts
Cam Bolts
I am going to install some polyurethane bushings on my L and some cam bolt kits. When I went to the parts store I asked the guy behind the counter for a cam bolt kit. He came out with two boxes that I assumed would work. Problem is, I think the parts are only for one side. Question is, Do I need a cam bolt kit that will provide for both sides front and back? The total amount of parts I have now is 2 bolts, 2 cam washers, and 2 nuts.
I just need to confirm my supicions. Thanks
You almost have enough for one side. For each side you need 2 bolts, 4 cams and 2 nuts. Some kits come with flat and/or lock washers too. Also, some of our trucks came with a cam on each bolt already, so if that's the case for you, you just need to duplicate your last purchase. If not, you'll need more cams washers.
