Summit Racing, 4wheelparts, National Tire and Wheel just to name a few. They will run about $125 or so and if you have someone install it expect to pay $300 or more. You can however do this yourself if you have a couple friends to help.
Not at all KB. All you have to do is undo all your existing body bolts, jack up the body from the frame, and then insert the spacers. All a body lift does is lift the body 3" higher than the frame.
