F150 7700
Old 10-28-2003, 07:44 PM
mockingbird's Avatar
F150 7700
This has probably been covered but I will ask anyway.
I have a 2000 Ford F150 7700
5.4 v8
3.73 rear
Tow Package
7700# option.
What is the towing specs for this truck? I have always gone with the 1999 F250 LD specs.
We are looking to upgrade our camper. I currently tow a 21' Gulfstream Amerilite 5er at around 5000# +-. The truck performs great but we are looking at 6000 to 7500 range upgrade.
Old 10-28-2003, 08:04 PM
DXprowler's Avatar
No problem! If you have a 4x4 your good for 8200#'s. A 4x2 will give you 400-500#'s more.
Check this site out: https://www.fleet.ford.com/products/...150_Ranger.pdf
Old 11-05-2003, 07:22 PM
sooo_alive's Avatar
Don't forget to look at the combined wieght limits (CGVW). That is the realistic limit.
Check out www.RV.net. The source for all things towing...
Old 11-12-2003, 06:23 PM
mjc3834's Avatar
Mockingbird,
The F150 7700 is a real sweetheart of a tow truck. I tow about 6500 total with mine and it tows great. I do use a premium gas Superchip program and mine makes close to 400 ft/lbs of torque but the stock 7700 worked fine too. However, if your current 21' is 5000# dry (brochure weight, no options or fluids) you're probably well under your 8400 max tow. If the upgrade is 7500# dry (brochure weight) you're going to be pushing that f150 REAL HARD. It doesn't take very long to add 1000# to the dry weight of a TT. Options, battery, propane, toys, and your family add up fast. If you've already done the numbers and 7500 is your total tow weight then you should be fine.
Quick Reply: F150 7700
