How much hitch drop?
? for the folks out there with a 03 Screw FX4 and factory hitch.
How much of a drop do you need for most of your normal trailering? I am considering a Reese 5.25" drop hitch to pull a snowmobile trailer and also a older boat trailer. I know there is a way to measure but since I tow different trailers, I want a happy medium. There is also a 6" or 3" drop, all will tow upto 5000lbs.
Thanks in advanced
Thanks in advanced
I have a 2000 F150 XLT ORP. Anything less than a 6 inch drop caused me a lot problems when I tried to unhook the trailer.
Most of the time I had to pull the pin out of the receiver and pull up so the hitch would pull out of the receiver, and then fall on the ground - this method doesn't work very well when you are trying to unhook the trailer on the side of a hill (paralled to the hill, NOT perpendicular)
