F150 trailer wiring
F150 trailer wiring
I have a 98 f150 with the 4 flat trailer wire connector. No tow package.
Need to convert to 7 wire and add brake controller (yes I will add tran cooler). I have an adapter to convert 4 to 7 wire but have 3 loose wire to connect. they are brake, power, and aux. Where do I tap into these?
Also will be installing brake controller..sounds like prodigy is the way to go. Is there a connector under the dash for plug and play? Do I need to have a special adapter/connector for the controller?
>> Bummer... ha, ha....
>> An easier way is to get the Ford 7 pin connector and wire harness. Lower the spare tire, look along the drivers side frame rail for the connection point and disconnect the stock 4 pin. Plug in the 7 pin and mount it to the bumper or where ever it works best. Get money back on that 4 to 7 pin adapter....
>> Pop for the extra $10 when getting the Prodigy and get the Ford wire harness. There should be a plug under the dash (right next to the COM port for the computer link).
You will also need some additional fuses and relays if not already present. These will go in the fuse boxes found under the hood. Your owners manual should have a diagram for the additonal 'trailer' fuses.
Good luck!
Mitch
Good luck!
Mitch
Although Mitch is sending you in the best direction, check out my gallery (link at bottom of signature) if you want the answer to your questions about the way you are doing it now. I had to do a quickie to tow a trailer and didn't have 7-10 days to wait for the wiring harness (thank you stealership). Total cost w/o brake control because I already had it was about 45-50 bucks. I show the wires to tap into in the rear harnes for the brakes and aux power although I didn't run my aux power from there. I already had an extra power line from the battery in the bed so I tapped into that which also means I didn't add the extra relay. (It only sends aux power when the truck is running if you use the regular aux power... I think) The other wire you probably have is for reverse lights which i didn't hook up either because the trailer I was towing didn't have them.
As for the controller, if you have one you can get the connector from several places (I got mine from Uhaul for about 6 bucks) it plugs in under the dash and you just match the wires up (***Be careful to check which wire is which they are not always color coded the same*** learned that the hard way when a friend of mine kept blowing fuses after installing his controler) If you are going to do much towing at all I would pop for the prodigy as mitch said. I tow once a year if I'm lucky so I went for something a little cheaper and to be honest it works just fine.
If you have any questions as to how I did it drop me a line and I will try to answer them for you.
What is the best place to connect the power wire (one of the 3 loose wires)?
Thanks.
