Tuner or Scangauge
Tuner or Scangauge
Hey everyone,
I just picked up my boat yesterday and it has a dry weight of 3200lbs plus the 1200lbs for the tandem axel traler and then all my goodies..
Anyways the truck pulled it just fine, even up the very steep grades we have here in southern california.
I was just wondering what you though would be the first thing to get for my truck, a superchips 1745 tuner, or a scangauge..
I dont have enough money to get both right now so thats why im asking...
do basically is this load big enough that i need to worry about watching my trucks status (scangauge to read temps, ect.) or should i got for the extra drivability and not worry about my truck as much...?
thanks,
thanks,
In my opinion,
It is always good to monitor truck status while in use. The sooner you are aware of a problem and can handle it in some form the better. Waiting until the idiot light comes on, strange noises eminate from under the hood, or copious amounts of smoke or fluid comes out the back is a bad thing. Personally I will be going the scangauge route rather than pod gauges. That way I can look at anything and everything while underway.
The supertuner is a waste of money EXCEPT for being able to firm up the transmission shifts.
It sounds like you are within the limits of the truck so I would opt for the scangauge first. Also, I would run the truck and boat across a scale to verify the weights rather than guess.
Russ
Russ
