towing the lightning
i have a 03 lightning and plan on towing it every couple months
my (planned) tow vehicle is my 04 expy it has a 5.4 it is 2wd and it has the factory towing package 373 limited slip rear and a nice hitch
i want to know how much can this thing safely tow
and how did it pull when you did it.
rick
rick
Originally Posted by lightninquick
what wieght would be considered pig
I did a quick search on Google and it looks like your Expy can tow up to 8,950 lbs. Ford's max tow ratings are often unrealistic - i.e. you can only reach the max if don't have have people, fuel and cargo in the tow vehicle and your trailer has too low of a tongue weight. But it looks like your Expedition has the best configuration for towing and a little extra capacity, so with the right trailer and travelling light in the Expy, you are probably OK.
An open car trailer suitable for hauling a Lightning is going to weigh at least 2,000 lbs, probably more like 2,500 lbs. A trailer with two 3,500 lb. axles and a 2,500 lb. trailer weight is only going to be able to carry a max 4,500 lb. load (if perfectly distributed), which is about what the Lightning weighs.
