Low Tow Capacity
Low Tow Capacity
i bought a used 02 [4.6l auto/ 3.08 gear ] last year.
i need to tow a u-haul trailer[ 4,000 lbs.] 200 miles.
the owners manual states that for this drivetrain combo. 2000lbs trailer
is the max.
?? would a two core radiator bring it up to snuff ???
and or an aux. trans. cooler??
is the max.
I think you will be all right if thats all your gonna tow and its a one time deal, although it won't be fun especially if you are going into mountains. Make sure your OD is off and you should be OK. If you are going to be towing a lot, I agree with kingfish51 and upgrade your rearend. Good luck.
I used to tow a boat and trailer that weighed about 2000-2500lbs with a 90 F150 with a 3.08 rearend. It wasn't too bad, but I also had the 5.8 v8. That did make a diffeerence.
As stated, if you are going to do a lot of towing, you might want to go with a 3.55 or 3.73 rearend. That is assuming a 4x2. If a 4x4, make that plural.
200 mile tow....
is the max.
is the max.
