Gas Mileage while towing?
Old 10-13-2005, 08:14 PM
EagleOne's Avatar
What kind of gas mileage do you get when towing with a gas powered F150?
Old 10-13-2005, 08:27 PM
Colorado Osprey's Avatar
A very subjective question.
It depends on trailer design for aerodynamics as well as tires, tire pressure, trailer weight, tongue weight, trailer load and much, much more.
With a small enclosed utility trailer with a light load you may actually get better milage towing than not towing.
But to answer your question from experience.
'03 extended cab 6.5' bed, 5.4, 3.55, 4x4 without a camper shell.
small light utility trailer open style 18mpg
small light utility trailer enclosed 19mpg
in-line 2 horse empty 17mpg
in-line 2 horse loaded 11mpg
slant 2 horse front tack empty 13mpg
slant 2 horse front tack loaded 9mpg
7K twin axle car hauler empty 13mpg
7k twin axle car hauler loaded with car weight 2500lbs 7mpg
10k twin axle car hauler empty 12mpg
10k twin axle car hauler loaded with 5000# car 6-7mpg
These are all relative as inclines will suck fuel like no tomorrow in a heavy load.
I hope this helps......
Old 10-13-2005, 08:43 PM
EagleOne's Avatar
Just woundering I towed a travel trailer to Gulfport, MS and average 8.5 mpg. That was a 400 mile oneway trip.
Old 10-13-2005, 09:53 PM
kd4crs's Avatar
Think in terms of single digits. I get 9 MPG towing my 26 foot travel trailer.
Old 10-14-2005, 12:56 AM
Chris3577's Avatar
Im looking to get a trailer about that size next season, out of curiousity what does ur trailer way when ur getting 9 mpg.
Thanks,
Chris
Old 10-14-2005, 09:58 AM
SVTPWR's Avatar
Not a F150 but my 05 F250 V10 gets 11.5 towing an open car hauler, race car and gear, 7k total.
Old 10-15-2005, 11:16 PM
ranger305's Avatar
I have a '99 Lariat SC, 4.6l, auto, 3.55ls. I get about 12-13 towing my 4200lb 19' boat ona tandem axle trailer. The windshield on the boat is probably 6-9" taller than the top of the truck.
Old 10-15-2005, 11:57 PM
ViperGrendal's Avatar
30' TT 5600# dry, 3.55LS rear end, 5.4, 02, 4x2
I get 8-9mpg towing. It seems to do better with the ARE cover on there. I guess it's helping the wind resitance some. On a trip to pensacola last year (800 mile round trip) I averaged 7-8mpg per tank. That was loaded pretty heavy and no cover (had the generators running in the bed).
Old 10-17-2005, 05:55 PM
acadianabob's Avatar
Here's the other end of the spectrum. I pull a 2,000 pound tent trailer with my 4.2L, 5 speed, 4x4 and consistently get 17 to 18 mpg at 70 mph; using 5th gear. So it all depends doesn't it? The only thing that knocks it down is a severe side or head wind. The worst I ever got was 15 into a 30 mph headwind; had to use 4th gear that day.
Old 10-17-2005, 06:12 PM
Raoul's Avatar
Certified Goat Breeder
Towing a 19' boat, total weight about 3200 lbs, I got 14 mpg.
The truck was getting 18.5 on the same route with nothing on the ball.
Old 10-17-2005, 07:20 PM
lees99f150's Avatar
try towing the boat with it on the trailer. I'm sure you will get better fuel mileage
Old 10-17-2005, 07:39 PM
Raoul's Avatar
Hey! It had a trailer!
Trailer didn't have no wheels but the boat was on a trailer.
(if the trailer had wheels I woulda got dang near 25 mpg!)
Old 10-17-2005, 08:34 PM
150Lariat2000's Avatar
What speeds are you guys towing at. I have not seen any gas mileage over 17 miles to the gallon. That is without towing. Towing I Was getting 14 to 15 towing a jet ski which weighs about 3,000 lbs. Just tryign to get ideas. I have a 00 F-150 extended cab 5.4 liter V-8 with 4X4, 6.5 foot bed with cover 3.55 gears too.
Old 10-17-2005, 08:36 PM
Originally Posted by 150Lariat2000
What speeds are you guys towing at. I have not seen any gas mileage over 17 miles to the gallon. That is without towing. Towing I Was getting 14 to 15 towing a jet ski which weighs about 3,000 lbs. Just tryign to get ideas. I have a 00 F-150 extended cab 6.5 foot bed with cover 3.55 gears too.
By the way, I have the 5.4 liter motor with 4x4
Old 10-17-2005, 08:45 PM
lees99f150's Avatar
on the flat i stay with the traffic, 65ish on the hills i slow. i try to keep the rpm's low. this helps save fuel. BTW im pulling 5k.
Quick Reply: Gas Mileage while towing?
