Wt distr hitch - do I need it?
I am getting conflicting words on weight distribution hitch. I am towing 3500 lbs camper trailer. Some recommend for WD, some don't. For instance, Ford website does not recommend WD less than 5000 lbs.
I also checked WD dealer sites. Rating goes like 6000 lbs/600 lbs and up. I can see from the way WD is set up why WD is not going to be effective for small downward pressure on the ball.
Question 1) Will I have a real gain from WD?
But I can see the advantage of sway control add-on to WD hitch even for my load.
Question 2) Can sway control be added to non-WD hitch?
Thanks.
Thanks.
Yeah, you could put sway on a non WD setup. As far as a WD hitch for that load, about the only thing I could see it really helping with is the trailer bucking on rough roads or if it's loaded down heavy in the front. If you get a lot of sag without it then you might consider it. A set up overload springs would help with that too.
Thanks for the advice. I will see how it goes with a standard hitch. If I add battries, LP tank, etc, total weight might go up a few hundred pounds easy, but still it will less than 5000. If I have a problem, I will ask you about spring setup. I have no idea what that means, and I may not be able to understand if it is a complicated setup. Thanks.
Helper springs is another common term for the overload springs vipergrendal mentioned. Most are an easy install. I installed some on an old chevy years back as the back end sank considerably when towing my boat. If I rememer correctly it took about 35 minutes for me to install. Most of that time was getting the pieces together and reading the directions. Here's a link to Hellwig's website:
http://www.hellwigproducts.com/helpersprings/heavy.html
However I towed a boat & trailer for several years with my 98 4x4 f150 no problem. It did have the trailer tow package and that may have helped as I think the rear leaf springs are a little beefier with a 4x4 and tow package - no real data to back that up, just seems stronger.
