Prodigy brake controller installation....bracket location
Hello,
I'm going to install my prodigy this weekend. I have all the items but I'm looking for ideas as where to mount the bracket. I DO NOT want to screw or drill into the plastic dash. I've noticed a nice metal bracket under the dash on the left side of the steering wheel. Has anyone used it?
thanks,
Bob
thanks,
Bob
Originally Posted by sadlerb_98
Ken07Harley,
Thanks for the reply. Did you just use the screws that came with the prodigy? Did you have to drill a pilot hole first? any pics of the finished product?
Thanks,
Bob
Thanks,
Bob
Yes, I used the supplied screws and drilled pilot holes first. Holes lined up perfectly with both of the ridges on the metal tab under the dash.
Originally Posted by Ken07Harley
BTW: My P3 came with 2 brackets. I used the metal one because it had a lower profile. ... and don't forget to install the relay that should have come with your Ford trailer towing package. Mine was in the glovebox.
I was wondering which bracket would be better. I plan on leaving the controller in the truck all the time so I wouldn't need the quick release bracket.
I installed the relay yesterday and plugged in the wiring harness. I just have to install the bracket and plug her in.
I'm still looking for a trailer to pull my jeep on. I want to be ready to pick one up at a moments notice if I see a good deal.
Originally Posted by pacificnw
I used the metal bracket on the lower left... no problems for me although some folks say it gets in thier way getting in and out of rig.
Nope, It isn't in the way at all. I drove around and hit the brakes several times without looking down at the brake controller and never hit it with my foot. I also applied the parking brake with no interference.
I didn't like the brake controller moved further back toward the rear of the dash. I couldn't see the readings as well and I also couldn't push the top two buttons or the manual brake lever as easily as I can now.
bob
bob
