Can my 97 pull this trailer??
I just purcahsed a 6X12 enclosed trailer that comes in at 1357lbs. I have a 1997 F-150 that is a extended cab with the manual tranny. I can not find the weight of my truck to save my life. The maximum GVWR is 6000lbs, and I wanted to make sure I do not exceed this. Also how do I tell what damn gears I have in the truck? The code in the door jam says axel 19...
Also you need to state, what engine and transmission you have. Manual transmission trucks have a very low towing capacity. Do you have the tow package, frame hitch, trannie cooler, etc. If you do not have a frame mounted hitch and a aux trannie cooler, you should get them.
Just about all the info you need is in the owners manual. If you do not have one, you can download one for free from www.motorcraftservice.com.
