first tow in truck
first tow in truck
Nothing real remarkable to report but just towed with the new truck for the first time. Its a 5.4 3v w/3.55 lsd w/factory tow pkg. Have installed cold air and better exhaust.
Trailer weighs about 2300lbs. I couldn't even tell it was back there when unloaded. With the car total weight is about 4800 lbs. I knew it was back there because the truck stayed in gear longer but the performance was great. I took the truck out of overdrive while off the hgwy but once up to speed I put it back into overdrive and she was very happy. Granted this is Dallas (read flat) and I kept it at about 65mph.
Overall very impressed. Truck has very happy towing the weight and I got almost no 'feel' that the trailer was even back there. This is what the truck is made to do and it showed. I was planning on setting up my equalizer hitch but now I'm not sure I'll even mess with it. The truck just pulled and managed the weight so nicely.
Going to a 7000lbs loaded enclosed V-nose in the fall/spring. I'm sure that will have a whole different ball game.
I'm towing 6700 lb camper with 35's tires and 3.73 gears. It pulled ok. The farthest i went was 75 miles from pa to ohio for the truck fest in canfield ohio. I drove with overdrive off and tach at 2500 rpm straights and 3500rpms uphills. I know I deeper gears cause of the 35's. that later on mod. It went smooth. When i turned on the overdrive It shifted a lot. so I kept it off.
You probably should look into some 4.10s or so. With those gears, you'll be turning about 2800rpm at the same speed.
Originally Posted by maskins
I tow a 7000 camper with my truck and until I go to the mountains or try to go over 70 I can leave it overdrive without it searching too much. When you put that 7000lb trailer you gonna want to use the equalizer then.
Yah, I def. plan to use the Equalizer once I get the bigger trailer. Actually, I need to just to be within limits on the class III hitch. I'm glad to hear you are pulling the weight though w/o too much trouble. fortunately, most of my towing is pretty flat down here. I still the 3.55 ring and pinion, it will be interesting to see how it does. Will prob. upgrade in the spring if it just bogs the engine down.
