Timbrens
The Timbrens is nothing more than a glorified bump stop. It will compress a little and then you will not have any rear suspension. What would really help you out is rear air bags. Air bags will give you active rear suspsension taht can handle 5000#'s...not that the rear axle is up for it...but the suspension will be.
1200-1600# pin weight...man-o-man.... that translates to 12,000-24,000# trailer. You are deep into 1 ton territory there with that load.
Check the legality of where you plan to travel with that load.
I am debating on the airbags vs the timbrens. Just wanting to smooth out when the rear drops on bigger bumps.
Timbrens work very well. The only people that don't like them are the people that don't have them. Seems that people would rather spend several hundreds of dollars on an opinion based on nothing. I have them and they can handle heavy use. Great part is that they do not wear out like air bags.
thanks Halrazr...appreciate the post and experince with the product.
trying to determine if I need them by looking at my spring hits based on towing. I can see some drop marks where the load pushed the springs down.
Best regards
JP
